AlChuck
When you upgrade from SONAR 1.x to SONAR 2.0, they recommend that you leave SONAR 1 there and let it install the new stuff into another directory; then later, run SONAR 1.x's unistaller to remove it if you want.
So today I tried that and the uninstaller crashed repeatably, each time it got to the point where it felt it should ask me if I wanted to letit remove some files in shared directories. It finally ran through to completion but without asking about those files at all, and as a result I no longer have my SONAR DX audio effects or DXi instruments.
Other than that it seems like stuff works but...
Has anyone else had any troubles with doing things this way? If you've been through it and restored everything to a perfect state and have any tips, let me know.
This installer stuff seems to get worse each year rather than better. I'd almost rather they just gave me the files and the needed registry entries and let me do it manually...
