N
nathanfunk
Hey nice people!
I'm a novice looking for some advice on upgrading my recording setup. I mainly record acoustic guitar and vocals both with a single mic. I invested in a decent mic (Shure SM-57) but I'm not happy with the sound yet. The likely reason is my cheap sound card - a Soundblaster Ensoniq (maybe worth $20). Recordings are a little noisy and slightly distorted. From reading up on general mic recording, a good pre-amp is important. Currently I'm using the "Mic-Boost" on the $20 sound card...
Typically that doesn't even bring the level up high enough, so I have to do a "normalize" operation on the wave data after recording. I'm sure you're all shuddering by now, so I'll quit there.
So my main questions are:
- What is most likely the main cause of the bad results?
- Will I notice a huge difference when recording through a more professional interface such as the M-Audio devices with built-in preamps?
- How much of a difference will I notice in switching to a better mic (>$300)
- Would it be smarter (in the long run) to invest in a separate mic pre-amp (vs. an interface with built-in preamp)?
I am planning to upgrade bit by bit and would rather buy excellent components that last a long time rather than continuosly replacing components...
Any advice and comments would be appreciated!
Thanks,
Nathan
Typically that doesn't even bring the level up high enough, so I have to do a "normalize" operation on the wave data after recording. I'm sure you're all shuddering by now, so I'll quit there.So my main questions are:
Thanks,
Nathan
