Armistice
Son of Yoda
Hi...
Finding the whole question of what levels to record / mix / master at a bit more complicated in Reaper than my good old stand alone machine.
Just want to check I'm doing, approximately the right thing as I have the first real attempt at recording a tune nearing completion.
TRACKING
So, individual tracks, the track slider is by default set to 0, and I adjust the gain on my preamp/interface so that the signal's coming in somewhere -18 to -12ish, ... I'm not recording stuff that has massive transient peaks, but the individual tracks are peaking somewhere in that range, although if it's over a bit, I don't sweat it.
MIXING
All those individual tracks add up, so as I mix, raise and lower individual track volumes via the track sliders, or various plug-ins, I generally end up with a mix that, depending upon which tracks I started with, is going well over 0 on the Reaper floating master meter, but it's not hitting +12, or whatever the maximum is. I don't hear any clipping. The floating master meter is working on its default setting, incidentally.
Now I understand this is too hot a level for mastering, so at this stage I can either reduce the individual track volumes via their sliders (painful) or reduce the overall level via the master slider (easy) until the mix is at a suitable level for mastering - that being what, exactly? I'm reading -6 in various places.
MASTERING
Having a correctly levelled mix I can then do whatever I need to get a 2 track master, that's probably another topic... I'm mainly concerned with getting the "pre-master level" where it should be for a master to be done... either on Reaper or by a real mastering engineer.
How are my assumptions?
Cheers
TRACKING
MIXING
MASTERING
Cheers
