X
Xpred
Alright. You may have noticed my multiple posts of problems with several issues. This thing has been driving me insane. Here's my story. Last week, I went out and bought the M-Audio FireWire Solo, the MXL 990/991 (One vocal/one instrumental) Mic kit, and accessories like XLR cables, pop filters, shockmount, stands, etc. So I install the drivers into my computer and hook it up.
The VERY first problem was that the input/volume level was way too low. You can barely hear anything at even full volume turned up on speakers. The recording amplitude on the sound programs also report it to be very very small. So it isn't speakers or playback problem, but rather input problem. I tried calling M-Audio Tech, and they suggested it was an IRQ problem. I checked my FireWire Controller IRQ, and I noticed that it was being shared with the video card (IRQ 16). Because my FireWire is onboard, I can do nothing about that. Now I go out and buy a cheap FireWire Card, and put it into my PCI slot. After messing around with different PCI slots, I come across an IRQ where it's not shared by anything. Now my new non-onboard FireWire controller is IRQ 18. OK, then I tried my system again. No luck.
I tried this with ANOTHER computer. Both computers are PC Systems running Windows XP SP2 with latest drivers on everything (chipset, audio, graphics, even mobo BIOS, etc, etc). Still the EXACT same problem. I thought it was the mics, but when I tested BOTH the mics, it was the same.
I thought to myself, maybe it's the pre-amp or the XLR cable. I took everything back to Guitar Center and they tried it on their laptop running a Mac OS. It worked fine. The pre-amp, XLR cables, and mics were fine. The volume levels were fine. I looked on several forums and found out that one person had a low-input volume problem with the FireWire Solo (!). Then I thought it could only be the FireWire Solo. I then thought to myself maybe my specific version of FireWire Solo has some problems with Windows or something. Then I swapped that out, and bought a NEW higher end PreSonus Firebox.
Now, after 5 days of mishaps, hassles, stress, frustration, driving back and forth a million stores for different things--I have my brand new PreSonus Firebox. I installed the drivers and plugged it in, and it STILL does the same. Still low volume input. On both preamp interfaces, the volume control & phantom power is ON! The gain/volume is turned up to about 75% all the way, and still low volumes. WHY?!
In my Control Panel, everything is fine. The recording devices were/are set to the FireWire Solo Mic 1/2 and PreSonus Mic 1/2. WHAT COULD BE POSSIBLY WRONG?! Either my two computers are just crappy, or God has put a curse on me that will never allow me to record music. I've tried different software, still same results. I've tried Goldwave, Sound Forge, Adobe Audition, and regular Sound Recorder. Two different pre-amps, and still the same problem. ARGH! Please someone help me. I've spent a week trying to solve this problem. If nothing else works, I'm just going to give up and never record again.
