Hey tree de lemon - Some programs have no latency compensation, some have it partially implimented, and some have it fully implimented. For instance, it may be implimented for inserts, but not for aux sends. I have a TC Powercore card, and the same latency issue exists. It's not the cards latency, it's the two trips over the PCI buss. I use Samplitude Professional, which I believe was the first program to offer full automatic latency compensation, and I can put TC plugs anywhere without latency issues. But when I first got the Powercore nobody had latency comp. So what you did is to create a stereo sub buss, insert a latency compensator on it, and route all the tracks not going to the DSP card to that sub buss. The sub buss then went to the stereo buss, as did all the tracks with DSP card plugins. This way, everything hits the stereo buss delayed by the same amount. It sounds like a bigger hassle than it was, but I sure was glad to upgrade Samplitude when they added auto-latency compensation. Anyway, check that both inserts AND auxs are compensated on your SW of choice.
