Two tracks
  • Thread starter Thread starter Zarathustra
Z
Zarathustra
I recently hooked my mixer into my soundcard, but of course, I'm stuck with a mono connection. Considering I'm playing alone at home, it's fine. I got some alright sounds from simply plugging my acoustic electrics into the board and also micing.
Anyways, I created a short sort of intro piece on House of the Rising sun, by recording first two slightly differently timed arpeggio tracks (not entirely an intentional effect, but it does create a cool delay sound), then a melody line and a very simple bass line.
The other is a fingerpicking of the chords of "Don't Think Twice It's Alright" by Dylan without a huge regard to the original fingerpicking pattern, my... unique vocals, and a melody line.
These two tracks are essentially rough-cuts, but they seem passable as they are to me. I'm more lenient about making mistakes nowadays, just because it's really just supposed to be fun, not taking a thousand takes/splicing them together. I did the parts entirely in each take I tried, then got rid of some of the verses and melodies were I goofed and stopped or whatever.
For the main guitar parts in "Don't Think Twice, It's Alright" I was using the microphone for my singing, so it sounds alittle more "electronic" than intended. I put a degree of equalization and reverb on that track as well.
Anyways, I know, I don't own good enough guitars and I suck at bass and my recording equipment is too poor for you to make any comments about it and my singing blows, etc, but I do want to share these, I think they're at least interesting. If anyone has any tips on removing noise or some constructive criticism on the mix/playing/whatever that's fine. I'm not picking a fight with you by not owning a $20,000 Martin, a $1,000 Microphone and a massive rack of recording equipment, or even lacking talent at what I'm doing.
Anyways, now that I've probably turned anyone from listening to them, here they are:
House of the Rising Sun (Intro):
http://www.box.net/shared/yrebk9o2s0
Don't Think Twice, It's Alright:
http://www.box.net/shared/cbpma8io0o
I can see links when I attempt to quote you, but not in your post.... :confused:
There is something shady about the site you're using. I get a pop-up blocker when I try to access it, and it's not showing up in your original post.
I think you need to find another source to post your stuff.
By the way, my anti-spyware program is going nuts....
House of the Rising Sun intro sounds pretty good, real short. It'd also sound a lot better with the guitars miked but it sounds pretty good.
I didn't have any problems with the site, but I use FireFox. A good place to put MP3s is: http://www.lightningmp3.com
They actually are miked, it's just the microphone output is very low and hard to balance with the pickup without being really noisy from cranking the gain.
I hope to expand the House of the Rising Sun piece, it's just that it's difficult for me to keep time for a long time, and that gets really hard to work with when multi-tracking. I suppose I''l have to find my metronome.
I was only using it because someone else was, if you want a different site that's fine.
http://www.lightningmp3.com/live/file.php?id=11432
Don't Twice It's Alright:
http://www.lightningmp3.com/live/file.php?id=11433
OK, just my two cents, but....
Can you give me a bit more specific answers on what mixer you are using, and what soundcard you have? I may be able to give you some pointers about getting better sound (more instrument, less hiss). And I also need to know what mics you are using....
What I heard sounded pretty good, but it could sound better. A lot of the hiss is probably due to one of a few things:
1. The guitar is mic'd and DI'd, the hiss is from the pickup.
2. The pre amps in your mixer are either shite, or they are in need of replacement; they are causing the hiss.
3. You are using some really cheap Radio Shack mics...
4. Bad cables.
You are on the right track, it just needs some tweaking...
Well, the bass has a Fishman pickup, the nylon-string has a no-name pick-up, but neither of them sounds noisy amped. I'm using a monster cable from the guitar to the mixer, but the cable from the output is an RCA to stereo plugged into a cheap soundcard.
The mixer is a Yamaha MG102C. It doesn't seem to get much mic signal unless the channels are maxed and the stereo output is maxed and the gain is pushed a bit up. The microphone is actually from a karaoke machine (I looked up the label on it), it was donated to our school, but it hasn't probably seen use outside of mine for awhile, because we have a set of better, matching mics.
At home I've only got this dynamic microphone, probably sub-radioshack quality, and I'm working with alot of substandard equipment, but this is miles ahead of my computer microphone.
How about the performances? I suppose I'm just setting myself up to get railed there. :D
J
Replies
26
Views
3K
Jeffaklumpen
J
R
Replies
25
Views
3K
TalismanRich
TalismanRich
K
Replies
0
Views
235
K-dub
K
Thekesslerboy
Replies
4
Views
668
Thekesslerboy
Thekesslerboy
