M
Mike Freze
Hi! Just a few questions concerning home recording with microphones.
1. I've heard of stereo recording/miking where you use two mics at the same time and send each one left or right in the stereo field for a richer, fuller sound.
Why can't you achieve the same thing by just using one mic, record your track, then duplicate that same track, then pan the original one side and the duplicated tgrack to the other. You could even control the effects for both tracks this way separately if you want. Am I missing something or will this give you the same end result as using two mics separately when recording a one track in your project?
2. What's the end result difference in miking a guitar amp to cature your sound vs. using no mic and just using your line out on the back of your amp into your interface and then to your recording software? Either way, you can monitor what you're playing in real time by hearing your guitar while you play through your speakers. Will either method produce pretty much the same sound for recording? If so, I guess you should always go line out to avoid mic bleeding from room ambience, other instruments. etc.
Thanls for your time!
Mike Freze
Mike Freze
