M
marshall409
Active member
Trouble with my cheap LP knockoff again. like most regular use guitars, i can see a little bit of fret wear under the string contact points. i fret pretty hard i think and bend alot.
the 16th and 17th frets have big gashes out of them under the high e string! this seems to have happened pretty suddenly, as i all of the sudden noticed it, and fret wear wasnt a problem at all before. im not sure how it happened, but i know it wasnt just worn down to this point. its like a deep gouge with a pretty sharp edge, and its just above where the string sits when i fret it, so if i bend above the 15th fret, it gets snagged on there pretty good. it comes out fine when i let go, it doesnt get stuck in there, so i guess thats good.
anyway, im thinking a couple new frets are needed. you cant really repair this right? the whole fret seems it would have to be replaced. ill be taking it in for a setup possibly tonight or this weekend, and ill show it to the tech and ask him what he thinks, but i was wondering what you guys might suggest and also how much i should pay (canadian or us estimate) for two frets replaced?
Thanks,
Adam
Thanks,
Adam
