Neil, I'd put it this way: there is no antagonistic (or say, 'neutralizing') conflict between tube electronics and soilid state electronics (per say). Both can be more or less colorizing in its own way depending on circuit design, components, condition of components and of course on how you apply (use) the 'device' (which is a combination of input signal characteristics and value settings of provided variable components).
Specifically, what ever the signal is like at output of your tube preamp will be affected by your recorder's solid state electronics the same way as a signal from a solid state preamp, or no preamp at all would. Another words, the solid state electronics of your recorder is not going specifically target "tube output signals" for annihilation, see what I mean?
Hope this make sense to you.
important thing to remember is that "tube warmth" ... is not automatic. It only occurs when you are hard driving the tube amp beyond its normally accurate limits
False. I have nothing to add here (not that I can't), but I don't want to start another "discussion". So, It's just false, period.
But, Just for fun of it, may I ask you, Tim G, what exactly do you "drive gently or beyond its norms" nowdays? Or is it just another "word of wisdom" based on heavy experience?
/respects
Now, Neil, ignore the bellow:
I hate to do it in your thread, but I had to respond ... that's my oblgation
treymonfauntre said:
regardless, i doubt getting some cheap tube preamp will really satisfy your needs anyway
Hey,
treymonfauntre ... or what ever your name is, How do you even know if Neil is about to get
some cheap preamp?
Speaking of being cheap:
the fact that you take the time to hunt down links blows my mind at how much of a god complex you must have
Nop, not in this thread, but in the thread in which
treymonfauntre has not make a single post, yet had an urgent need for silent fart, and so he released what could not be held.
treymonfauntre, I missed you, dude.
the problem is, though, that you are not telling the truth. One must actually
have mind
to get it blown.
Now, go back to studying gear prices. Have it your way and have a real good time. After you learn something new, stop by and drop an invaluable note or two.
/no respects what so ever
