soundchaser59
Reluctant Commander
Being new to the tube mic preamp thing, I have encountered unfamiliar ground here.
I have a generic dual channel (low voltage) tube mic preamp. (not a "tube mic" but a tube preamp) When I first turned it on, I found that both channels could be set with identical knob settings and they would produce the same sound. I could switch mics around and still both channels would sound the same.
But now, one channel is becoming distorted, and the output level is very hot even if I turn the knobs down (ccw) really low. It sounds like the same distortion I would get if I ran an instrument too hot into the mixer trim, that kind of hi freq buzzy/fizzy/static-y distortion. I know it's not the mics because if I switch the mics the distortion stays in the same channel all the time. It's mildly annoying because the tubes only have about 20-30 hours of use on them. Shouldn't they last a lot longer than that?
Is this an accurate description of what happens when a (12AX7) tube starts to go bad?? I'll find out for sure (I Hope!) tomorrow night when I remove it from the rack and open it up to change the tube. But just thought I'd ask to see if anybody out there can say for sure, "Oooooh Yes! That's exactly what it sounds like!" or "No way, SC, you need to hire a real engineer!"
Thanks!
Thanks!
