M
MatchBookNotes
Hey, what kind of mods can you get done to old point to point circuitry tube amps?
cool on the remake. I have an old guitar mate 2. it has 2 el84 or 34(they're thin and long and i know there's a difference, i wont' be doing the modding myself for a long time) and 2 12ax7a and one 12ax7u. I don't really like the tremolo that's on it, maybe add a reverb or what is there? I don't want to complicate the circuit too much but the boost/trebble switch seems pretty useless in my opinion too. the boost just makes it really muddy not really a boost of anything.
Long and thin would be EL84s.
As to what can be done, just about anything. As to what YOU can do, it depends on how much time you want to spend learning about this stuff. It all depends on what you are after - you'll have to describe what you want a bit better. I've not been that happy with my amp's tremolo recently, so I've been working on redesigning it with a solid state oscillator (which should improve it quite a bit). Adding a reverb is more problematic. The tremolo probably only uses one half of a 12AX7, and a reverb needs two halves IF you want to keep a 100% tube audio path. You could do it by using solid state for either the driver or the make-up stage, but then you need to put in some other power supply for the transistors.
To a large degree, once you understand the basic topology you can look at other schematics and take the sections you want for your amp. It's less than ideal to be adding tubes, but most other things can be accomplished if you think hard enough.
As a first step, you might try recapping the amp. If it hasn't been used a lot, the electrolytic caps are likely to be dried out and in need of replacement.
Light
"Cowards can never be moral."
M.K. Gandhi
By the time you get thru paying for mods you could just buy an amp that does what you want already.Why pay $600.00 to $800.00 to have Bray modHey, what kind of mods can you get done to old point to point circuitry tube amps?
