powderfinger
I'm away from my digital recorder all month and have rigged a setup to record. This is what I've got: an 8-track mixer and two old tape decks. So I've figure in order to multi-track, I can run one deck into the mixer and one out, running it in when I want to add tracks while recording. So my question is, what is the best way using a setup like this to achieve good sound quality? Should I try not to record over pre-recorded tape, does this significantly diminish quality? Is there a certain quality tape to use? Probably at most, I'll have four overdubs on top of what is originally laid down. Should I have a tape for each overdub, or will two do the trick with no loss in quality? Any info will help. Thanks.
