Triggers???
  • Thread starter Thread starter soundprizm
soundprizm
Hey, I'm wondering if there is a way to put a trigger effect on your kick after you are done recording? Maybe a plugin or something? I am trying to get a sound the Fear Factory, I know that guys uses some triggers.
Do you mean you're recording an acoustic kick and want to change it's parameters after the fact?
If so, keep your kick isolated in the mix and then just assign the effect desired to it.
Or you can put a trigger on it and run it through your FX and into the mix.
Yep....its easy to trigger a drum trigger with a prerecorded kick, but you'll need a drum module...or sampler. I use the DM5 and have good sucess with it
