B
bdam123
Member
So for the past week I've been trying to soak up as much knowledge as I can about treating room acoustics. Unfortunately, the more I read and learn the more I feel like I know nothing. I was hoping some of you guys could help guide me in the right direction and answer a few minor questions. The room will be used for mixing and recording vocals. Thanks in advanced.
My Current Plans:
My room is 18' L x 13.5' W x 8' H. Obviously my work station will be facing the short wall. Opposite of that, on the other short wall are two windows that I plan on covering.
I plan on having panels at the first reflection points (either side and above the listening position), a bass trap centered where the front wall meets the ceiling, and bass traps in all four corners floor to ceiling.
My Questions:
1) Will 3.5" Roxul with a 2" air gap be sufficient for the first reflection panels?
2) I plan on making the bass traps 6"-7" thick. Should I superchunk the corners?
3) Should I cover the rear windows with 3.5" panels or the 6"-7" panels?
4) Could my room use Diffusors? I was thinking the back wall between the windows. Should I put diffusors over the windows instead of panels?
5) I read somewhere that one should only use 2D Diffusors on the ceilings and 1D for back walls? Thoughts?
I honestly have only been doing my research for about two weeks so I don't have a clue about any of the charts and data one can accumulate pertaining to a room. I feel like if I was going to learn all of this stuff before I worked on the room, it wouldn't be built for a year due to all the thing I'd have to learn. So my apologies for being such a noob.
My Current Plans:
My Questions:
