alien
Adding on a control room was out of the question financially, but it's what I really wanted, and needed to do.....oh well, as usual, I do the best I can with what I've got lol.
In order to maintain as much isolation as possible without reframing the entire structure and also to maintain the cubic footage for the control room area, I sat down with a calculator and went at it.
The room has seen 3 phases: 2 car garage, live band practice area, home studio.
First thing I did when I finished the interior to convert it from a 2 car garage was to levae one of the garage doors and frame in around the door track. This proved to be VERY beneficial in the latest phase as I already have the cieling and back wall isolated.
I used a single frame design with 1/2" Moisture resistant sheetrock. The MR sheetrock is a bit more dense than the normal. I went with R-13 Sonobat insulation as well. The interior was carpeted on the walls and cielings using an indoor/outdoor carpet I found at Lowes for $0.47 sq/ft. The backing of the carpet was a layer of rubber coating that was about 3/32" thick. I then used RPG Profoam to further dampen the front wall. I made the windows from 1/8" and 3/16" thick glass with reservation to add a 1/4" piece if needed.
Previous setup had me in the same room with the drums and vocals making mixing impossible and post process a nightmare.
My goal?
Within budget, isolate the drums and vocals as much as possible so I could efffectively mix them at the console.
The result?
Vocal booth - simple enough. 95% isolation.
Drum Room - Nightmare, but worth it. 93% isolation.
Pics:
http://www.lychesis.com/album/
(click the boxes at the bottom to see the pics)
My goal?
The result?
Pics:
