J
JiMoSiTY
As I mentioned in my last post; I have been using Cool Edit Pro 1.2a for a couple years without a problem. I usually record several tracks and then use the "Save All" command to save each individual track as a separate Windows PCM .Wav file.
Recently; I have been noticing that it has started saving the files without a .wav extension, so they just show up with no file extension, which is only slightly annoying.
Did I change a setting that I shouldn't have?? I don't remember changing anything actually, but if someone knows the fix for this; I sure would appreciate it.
Jim Rodgers
jim.rodgers@zf.com
Jim Rodgers
jim.rodgers@zf.com
