B
Bob's Mods
The last nagging problem with digital recording for me is the track to track definition issue. I understand and have worked out solutions and methods for dealing with common problems that can arise in digital recording but track to track definition is one I must work around.
I am my own everything, writer, recording studio engineer, musician, janitor, singer, etc. My common method of recording is track layering. Although we may all have an unlimited track count, I have found this to be almost meaningless as piling on the tracks causes more and more loss of track mix definition. I have found that recording at 96kHz rather than 44dot1kHz reduces this problem greatly but I don't like the change in sonic character 96kHz gives me nor do I care for how much resources it uses. I've also tracked at 48kHz and that does help provide for better track to track definition in a mix but not as good as 96kHz. My preference is to work at 44dot1kHz and massage the mix to bring out the tracks.
My rules are to center the drums and bass. From there I try to isolate vocals by panning to one side and panning a single dominant instrument on the other. This appears to provide the greatest clarity for mixing. By mixing in a way that allows for a dominant track on the left and on the right channel, I find I can simulate a well recorded tune.
It is my belief that if I were able to record a full band in one take plugged into a mixing board mixed down to two tracks this problem would not exist. I suspect mixing in analog would provide for a better track to track definition than digital mixing does. I believe that analog mixing is probably superiour to the digital mixing I am forced to do.
Has anyone else been fustrated by this annoying problem? It is not impossible to work around but you must adapt your writing to make best use of the digital medium compromises that must be made.
Are there others out there who layer tracks like myself and have discovered this to be a problem too? Or....is mixing that much of a craft? There is a lot of newgroup buzz on the black art of mastering but I have found mixing to be more of issue mastering. I believe too much is made of mastering buts its really mixing where the bullet hits bone for the home recordist. If your mix is right, then mastering only adds that extra few percent.
Bob the Mod guy
Bob the Mod guy
