K
kelhard
Hey there.
I'm working on a track and there is a problem on the guitar track. Once I fix the problem and play it back, the tonal balance changes considerably for that split second.
What I'm doing is fixing an audible noise in a guitar track. The guitar was recorded in stereo, onto separate tracks. I go to each track separately, find a section of the same riff, copy it, and paste it into the section with the audible noise. When I play the track back on its own, it sounds fine. No audible clicks, and everything is in time. Same for the 2nd guitar track.
When I go back into the multitrack field, the tonal balance of the guitar track(s) shift considerably. I don't know what has happened.
When I go and mute the guitar in the left channel, the right channel sounds perfectly fine. When I mute the guitar in the right channel, the left channel sounds fine. When I put both tracks together again, the tonal balance shifts.
I've tried inverting each of the "edited" sections to see if that could help. It doesn't. I tried inverting only one channel (experimented with each one separately). It doesn't work. I've tried copying and pasting the sections into their own tracks, and replicated the exact same EQ, Panning and Volume settings as the "originals". It doesn't work. I tried adjusting the volume and panning (many different settings) on just the edited sections alone. No avail.
If anyone here has any suggestions, I'd love to hear them. I'm almost at my wits end here.
My last resort is to get the guy to play the guitar track all over again. Because we recorded the guitar in sections (He'd play good for a bit and then make an error, so I'd just start again on a fresh set of tracks, and I pieced the guitar track from 3 different "takes"), it will be hard to get the exact same sound, unless we do the whole thing.
Any suggestions????
Any suggestions????
