witzendoz
Senior Member
Yup....a few dozen or more edits.
OMG....I could cut up a bass track in like 15-20 minutes, select the offending notes as a group if they are all about equally too loud, and then pull down their level.![]()
If I had to do individual notes...add another 15 minutes.
I just don't buy the EQ/Comp approach because it's going to affect more than just the level of specific notes.
I know some folks want that one-click easy way to solve problems...but I prefer the more surgical approach, and that's what the strong point of a DAW is.....the ability to make precise edits/FX/processing...unlike working with say, a multitrack tape mixdown, where you are more forced to apply broad-stroke solutions....like EQ/Comps/etc across the entire track.
After you do it a few times, it's actually pretty fast slicing up an audio track and making individual edits
So is this saying that all the recordings of bass done in the analog world when a bit of eq and compression improved the overall bass sound are no good? As a matter of fact I still mix in the analog world so I have outboard compressors and eq for just these little problems. I could edit the notes on my hard disk recorder but why when the eq and compression works fine?
Alan.
