tl audio ebony a3
  • Thread starter Thread starter deibid
D
deibid
& just when i though i'd made up my mind what preamp to go for.....
it's pretty frustrating choosing the right equipment.
anybody here had any experience with the tl audio ebony a3?
tl audio ebony A3
Greetings,
I just received mine, and have had a week to try it out. I’ve recorded two snare drums (one close mic’d and one overhead mic’d), a mic’d acoustic guitar, a bass guitar (direct), an acoustic/electric guitar (direct), and a Vox ToneLab (the old blue one).
First, my overall impressions of the 3 sections of the unit:
Mic preamp: Pros - quiet, neutral, clean. Cons – could use more gain for ribbon mics. Not much headroom – you can get a “bump” on transients if you drive the input too hard.
EQ: Pros - musical sounding, easy to dial in a good sound. You would think that having fixed low and high bands and only the mids sweepable would be a hindrance. But in all my applications, I was able to get exactly what I wanted. Cons – can add a bit of noise at extreme frequency boost settings (as to be expected, especially with high frequencies).
Compressor: Pros – can either be subtle or really mangle your signal. The “Soft” knee setting is best when you want a bit of signal control; the compressor is fairly unobtrusive and transparent in this setting. Cons – The “Hard” knee setting is useless. The gain reduction almost seems to be random at this setting. I guess you could use this for extreme mangling, but forget using it for anything else. This aspect of the compressor really needs a redesign!
I first tried it out by micing an acoustic guitar with a CAD M177. The guitar is a Dean “Ovation style” with a composite back. I was able to dial in a sound that was very musical and smooth by using just a touch of compression and EQ. The cool thing is that you can turn on the “Tube Stage” and dial in a bit of distortion, giving the impression of tape saturation.
On the close-mic’d snare drum (again with the M177), I was able to use the comp and EQ creatively to get a nice open but controlled sound. Very natural but with enough character to make it interesting. The only slight problem I encountered was adjusting the input gain as to not cause that odd “bump” on higher input levels. This isn’t a huge problem, but you have to be mindful of it.
The overhead mic’d (M177 again) snare was a hoot! I wanted to get a “Peter Gabriel-esque” Fairlight snare…and I got it! I tuned the snare almost slack, and then dialed in the comp and EQ ‘til I got what I wanted. To me, this is what the A3 excels at. It can add some serious character to a signal, but still achieve a musical and useable sound.
The direct bass guitar was really smooth; very even across the frequency range. Frankly, I’ve never gotten a better direct bass sound. The only downer was the compressor. Even in the Soft knee setting, there was a bit of distortion added, even after fiddling with the Attack and Release buttons. Variable controls for these would be a definite improvement. Ultimately, the distortion isn’t noticeable in a finished track, so I can live with it.
The direct acoustic/electric guitar and a Strat into the ToneLab worked really nicely. The EQ and comp added a nice “roundness” in both cases. I was able to get transparent level control with the comp, and the EQ brought out a bit of sparkle and edge, without sounding harsh.
I haven’t recorded vocals through it yet. I’ll follow up when I get the chance.
Ultimately, would I buy it again…or recommend it? Yes I would buy it again, but I recommend it only if you have a “clean” unit (like a Focusrite ISA One for example) to compliment it. I wouldn’t record everything through the A3, but for adding some coloration, I would give it serious consideration. I would give it a grade of B.
To give some perspective: I’m not a professional engineer, just a song-writer/experimentalist with my own home studio. I don’t own any high-end gear (like Avalon, Manley, etc.), but I am developing a picky ear. I wanted to step up from the ART and lower-end stuff I currently track with, and got this at a good price, so figured “What the heck?”
Hope this helps…
