60sRockManiac
Hello all, I'm working on an acoustic/voice cover (looks like I won't be getting to lay it down tonight) and I'm trying to get a good single mic placement. My microhpone is an Audio Technica AT2020 Cardioid Condenser that cost me about $100 and arrived last week. I've been trying to place it so that I get a good, crisp vocal and rich guitar sound, with a slightly voice-heavy mix. I'm starting to think this might be too much for one inexpensive condenser.
I've been having some trouble finding a sweet spot. If I put it 3-4 feet away, I get a lot of guitar and the voice sounds like it's in another room. If I bring it close, I get a slightly mid-rangey sound with a good enough mix, but when I try to EQ up the treble, the guitar sounds rather like one of those bad acoustic-electric setups from an early 2000s concert and the vocal gets buried again. I actually used to get better sound just putting an SM57 with a pop filter up to my face and adding a little EQ and reverb.
Where should I place the mic to remedy this, and should I be using high or low gain to get the best result? I'm also wondering if I might change rooms. I usually have success recording in my bedroom, but should I try moving to an acoustically better room when nobody's home to record? Or should I just go back to the dynamic mic?
I appreciate any advice I can get. Just note that I do not have an option to use 2 mics, as I operate on a single-input Shure X2U interface and don't have a pre-amp with any fancy settings.
Thanks in advance!
Thanks in advance!
