B
BookSix
Ok, I want to set my studio up in the garage (2-car) but I have limited dampening material and the garage is basically an echo chamber. Concrete floor, all sheetrock not to mention 2 ceiling heights... First, I was thinking of putting 7mm Laminate wood, from ikea, over the concrete:
http://www.ikea.com/webapp/wcs/stor...tId=47543&langId=-1&chosenPartNumber=70082182
I also have about 12 2x4' pieces of auralex (yeah I know, but atleast it's a start... and I'll probably buy some corner bass traps (or make some of rigid fiberglass) and make a couple diffusors (such as the one made from 2x2's). I'm trying to decide if I'd be able to afford making a decent sounding room out of this or if I should stick with the 10x10 bedroom. I'll mainly be tracking acoustic guitar and vocals (most of the other stuff will be done in the computer or at commercial studios). Who's got suggestions on how I could make this room work? Here's a diagram of the garage:
www.brettmichaelwiesman.com/temp/garage.jpg
For $80? Huh. You could do that since its removable. Laminate floors float on a layer of thin foam and the individual pieces lock in to each other. It would be easy to remove when you leave. I think thats a good idea if its that cheap. If you can, at some point hang some 4" fabric wrapped rigid fiberglass "clouds". One or two over you mixing station and some up in the high part of the ceiling. Depending on what that ceiling geometry is like, you may want to straddle a few wall/ceiling and ceiling/cielng corners with the same material if your budget will handle it. Rigid fiberglass come in 2'x4' panels of various thickness. Use 4/6" across corners for good low frequency/modal absorption. Use it over your mixing station as early reflection absorption. Leave at least a 1" airgap between the fiberglass and the ceiling. A good way to hang these is fabricating a metal grid from standard suspended ceiling grid components. You can even build a frame that supports the grid as well.
