"Thunder" - Instrumental Prog-Rock
  • Thread starter Thread starter stivens1991
stivens1991
Hi,
Recently I've recorded a instrumental track in my home studio. It would be very helpful if you could tell me what issues do you hear in the mix? Levels? Freqs?
km7.wav - Google Drive
Stuff I used:
Schecter Demon FR7 with EMGs 707
Focusrite 2i2
Spectrasonics Trillian
EZDrummer 2 (Progressive)
Grind Machine II VST on guitars
bunch of free VST plugins.
Thanks!
Przemek.
I thought some of the tracks sounded pretty good. There is a crunch guitar on the left side that I liked. There were some other crunch guitars that sounded good too. Maybe just a bit too much gain. They sounded like amp sims, but decent ones.
Some of the tracks are really saturated in reverb and tremelo. A bit too much I think. The guitar in the intro was a bit rumbly.
The drum samples are a bit grating. The cymbals are really sizzly. If you have a high boost on them, I'd remove it. If not, I would go with other sounds. The attack on the snare/kick/toms is a little clacky.
You set a real cool atmosphere tho. The parts are pretty intricate and well thought out.
There's a disconnect between some of the guitar reverb which sounds like the guitars are being played in a cavern and the drums which have more of a hall reverb on them. Just a bit too much reverb for me
Really cool idea you have. The other posts nailed it. I was going to comment on how the the low-end reverb kind of drowns everything out. I think there's a reverb balance you can strike that could be more suitable for your song. Maybe use some doubled tracks with delay/reverb on the secondary/tertiary track, or use some predelay on the reverb plugin to ensure the clarity of your instruments can be heard without being lost. EQing reverb is also a good way to use it effectively. Those would be my thoughts going in to make changes. Hope this helps!
