H
Hornplayer
Well guys I'm really stumped on this one.
Technical data:
Sonar 3PE with 3.1.1 installed
Tascam FW-1884 with drivers 1.1 plus firmware at ARM135 FPGA49
I'm mixing a 16 track project down with the help of my FW-1884. All is working fine. Saved the project and worked on it again a number of times. (this is after the PE3 3.1.1 update and the FW1884 firmware update.)
I sit down tonight, bring up the project and I discover the first 8 tracks (1-8) of the project will not play. The last 8 (tracks 9-16) play just fine. The Aux 1 and main bus play fine as well with appropriate meter readings.
No tracks on the first 8 are muted. In fact I can't solo them either. No amount of soloing muting, or even track deleting has helped.
When I mute the tracks the mute button lights, same with the solo light. They just won't play back.
I don't know if it's possible to mass mute 8 channels at one time without the mute buttons lighting. (I don't think so)
I loaded another project in with 16 tracks, and all tracks play back fine as they should, so I'm pretty sure the problem is isolated to the one project I'm working on.
I think that I can load another project up with no problems eliminates any FW-1884 problems, and probably PE3 problems. The only thing I can think of at the moment is that I've discovered a bug, by executing a sequence of events, (eq, compressors, effects etc) in some kind of sequence that Sonar didn't like.
I'm beginning to wonder if I clicked a secret button causing the first 8 tracks to mute.
I'm clueless.
Any ideas?
Thanks in advance for any replies.
John
Technical data:
I'm clueless.
Any ideas?
John
