5
5c0tt
Hi guys. This may turn out to be a lengthy post but I'd be really grateful if you stick with it & help me out. Some of the questions are probably very basic but I want to understand the facts before I go spending my cash.
So, I'm thinking of buying a module. I do pop/rock/alternative type stuff mainly, but I dabble in a bit of everything really.
I'm thinking Roland XV5050/EMU Proteus 2000 at the moment.
My main gear:
PC running a fairly basic midi sequencer.
Korg D16 multitracker- everything ends up on this.
Alesis SR16 drum machine.
Cheap Casio keyboard, complete with cheesy sounds & high noise floor.
Midiman 4x4 to get them all talking to each other.
Various other bits of kit- preamps, mics, monitors, guitars etc etc
How I normally work:
I input notes to my sequencer from the Casio- these notes trigger the Casio sounds & the SR16. They both output to the Korg.
I record my guitars, vocals etc to the Korg, using the Korg as the master clock to run the sequenced stuff.
Once the tune is 'ready', I dump the drums & keyboard sounds to individual tracks on the Korg then do the mix.
All pretty standard I guess.
So, to the questions:
1.
My Casio is easy to understand- if I choose the notes on track 1 on my sequencer to be, say, piano (000 GM format of course) & track 2 to be strings (048) then that's what I get.
Easy.
But on a module there seems to be performance mode, patch mode etc. The patches may be like 4 tones all played together with effects and stuff- would I be able to put the 'Megastrings With Piano and Effects' patch on track 1 & then 'Synth-lead-multi-voice' on track 2 etc etc? Or would I have to use the raw sounds from the module & build up the tones on seperate tracks to get the same sounds?
I understand polyphony & multitimbrality (is that a word!?) so there's no need to go there.
2.
The units I mentioned earlier have built in effects processors.
I've tried to find out but I can't determine if the processors are insert type effects or 'global' type effects. For example, could I treat my strings track to reverb, chorus & multi fx, then treat my other tracks to completely different reverb & chorus settings or would I be stuck with a send/return global effect type situation for all the sounds I'm using?
3.
The XV5050 is 16 part/64 voice with 4 outputs + S/PDIF.
The Proteus 2000 is 32 part/128 voice with 6 outs + S/PDIF.
I've read good things about the XV's sounds.
I've read not so good things about the Proteus sounds (they can't be that bad can they?) Also, I've read that the Proteus sounds more like a dance module than a general module- any comments? I'm more interested in a good general module.
The XV costs 600 UK pounds. The Proteus is 450 pounds.
My budget is tight but, if it was worth it, I'd go with the XV.
God, I hope that lot makes sense- I've had quite a few beers!
If you've read this far- thanks! Any advice you may have is welcome.
Scott
My main gear:
1.
Easy.
2.
3.
Scott
