T
timandjes
Just wanted to post what I've learned after a month of use on my electronic drums. I wasn't sure electronics were the right decision when I got mine... Maybe this can help any of you who may be trying to decide...
Here are the Pro's & Con's I've seen, the con's first:
1. You can't stand on top of your bass drum like some of the rock stars in live concerts.... If that's important to you, get a really good acoustic kit!
2. Electronic's are not usually as eye catching as the colorful, shiny acoustics so, I'll agree.... they're not as good looking. (You may even be the scum of the earth to some die-hard acoustic fans... Kind of like riding your new Yamaha motorcycle through a pack of die-hard Harley fans....)
3. They are definitely not as rugged... My kids could climb over my acoustic kit with no real treat of damage... On the electronics, (those of the affordable price range anyway), it probably wouldn't take much for my two-year old to hang on one of the arms and break the plastic clamps that come with them.
4. The pads are small, on mine only 8" in diameter. My acoustic kit has much larger heads, which means a much larger 'target' and easier to play, (easier to hit the target).
5. The pads can be a little less responsive in fast sticking and may not always pick up each one of your licks if you're doing some pretty fancy stuff... However, there's a broad range of adjustment settings that you can perform to adjust the sensitivity. (For me, I just keep an acoustic snare by the kit and on marchy, orchestral songs with a lot of snare rolls, I use it) (I totally agree with what one of the people said in my other post about electronic drums regarding them not being as sensitive as acoustics...)
6. If you learn to live with the lack of sensitivity and stop some of your fancy stick work because of it... well, you know what happens when you stop practicing something..... (Again, however, there's a lot more sensitivity settings you can play around with which should address a lot of the sensitivity issues..)
Ok, now some of the good things I've noticed....
1. Those little 8" pads I complained about above... Guess what, they made me a better drummer.... I'm forced to strike a much smaller target and after about a week or so, I'm totally used to them.. Even after playing an acoustic kit for 21 years...
2. Volume control... I can't stress this enough... e-drums are a life saver here... I was so sick of trying to play softly on my acoustic kit... Now, on the e-drums, I can play at a comfortable velocity and just turn the drums up or down to suit the sound guy...
3. Over a thousand different voices! You simply press a button to instantly change your kit to a jazz kit, a rock kit, your cymbal from a medium crash, a paper-thin crash, your snare from a wooden snare, a metal snare, or just about any other sound you can think of including some really cool sound effects, just as fast as you can press a button! Try that with an acoustic! Sure you can trigger an acoustic but in the end, you'll most likely have spent A LOT more money than the e-drummer did.
4. Easy to record!!!! Here's the biggest difference for me.. My band recorded a CD last year & I used acoustic.. That's when I learned about problems with proper mic placement, phase cancellation, all those wires running everywhere, mic stands everywhere, and the requirement of Total Silence around you while you record with mics.... (Try that if your studio is @ home & you have 3 small kids running around!)
With the electronics, you could record with train going by your studio! There's no mics.... Just one 1/4" line from your kit.
5. And about those cymbals that everyone talks about.... Hey, to me, they're fine. I bought several expensive cymbals and I always seemed to want a different sound. With the electronics, (which is a just a recording of some really nice cymbals that is programed to sound when a trigger is activated), a different sound is just a button away & hundreds if not thousands of dollars cheaper! (If you have a really nice brass cymbal and record it, does it then sound like crap on the recording?????)
6. For the beginning drummer, because of the ambience and sound effects built in with the electronic kits, you can sound Really Good, playing some really simple fill patterns... (patterns that would 'sound' like you're a beginner & perhaps even 'boring' on an acoustic kit, unless you 'transformed' the kit into electronics anyway through mics, amps, FX modules, etc..)
7. Easy to move! Wow, here's another big one... the e-kits fold up small enough to fit in just about any car. Even small acoustic kits would require a much larger vehicle with little room left for occupants...
All in all.... I love 'em so far! They're not perfect, but I totally disagree with some of the posts that say they "totally suck!" At this point, I plan to play them for the rest of my life, and when & if the time comes.... I'll buy another e-kit! (but if I find a good deal on an acoustic, I might buy it too!)
That's my story!
With the electronics, you could record with train going by your studio! There's no mics.... Just one 1/4" line from your kit.5. And about those cymbals that everyone talks about.... Hey, to me, they're fine. I bought several expensive cymbals and I always seemed to want a different sound. With the electronics, (which is a just a recording of some really nice cymbals that is programed to sound when a trigger is activated), a different sound is just a button away & hundreds if not thousands of dollars cheaper! (If you have a really nice brass cymbal and record it, does it then sound like crap on the recording?????)
That's my story!
