The use of a preamp...
  • Thread starter Thread starter lapieuvre
L
lapieuvre
Member
Hi,
I first bought a good mike (AKG C2000B), then good studio monitors (Samson resolve 65a), now I am going for the preamp... With a mackie CFx16 I get good sound but I don't have the warmth of a tube preamp... It is kind of too clean... (I do pop and Rock). So I tested behringer ultramic v2200 (1 tube)... sounded ok... then tested a presonus preamp (with only volume and gain), sounded hot... Now the seller suggested me to buy a... forgot the name but it wasn't a tube preamp... what is the use of digital preamp if I got all the effects needed (tube simulators, de-esser, compressor,etc...)?
Is there a FAQ on this? What do you guys use in the budget of 100-150$ CDN? I mostly record voice, tambourine electric guitar and accoustic guitar.
Thanks,
Lapieuvre
lapieuvre said:
Hi,
Thanks,
Lapieuvre
Your budget is not going to get you much in the way of a decent pre unless you consider checking out an ART MP or a used TPS II. A DMP3, which is an excellent budget pre can be had for approx US$175 ($200 CDN).
For addtl info on pre's, utilize the "SEARCH FUNCTION" of this BBS.
I've found mixed readings on the TPS II in previous research. Some love it, some hate it. Whats your take?
As far as I know it's basically an MP with more features. I wouldn't recommend anything that cheap from ART for anything more than a bass DI.
Exactly!
It's the ONLY reason why I bought it!
If you're on a tight budget then I'd ditch the idea of a tube preamp. Tube pres at the pricepoint you've described are totally different than the high end tube units renowned for imparting a nice tone on the signal. With most of those units they just lob a tube in there somewhere for marketing purposes.
The only possible exception is the Studio projects VTB-1. It doesn't sound like a proper tube pre but it's useable.
If you've not got much cash I'd go for something that's going to give you plenty of nice clean gain. The DMP-3 would be my choice which means you'd have to save a bit more.
You can get useable gear at incredibly low prices these days but there is still a line there.
