P
planeman
For sale is a Mackie 808s PA system in Perfect condition, cosmetic and sound wise. This pa Is literally brand new. The mackie 808s is a Powered Mixer for the Professional. With features like: *1200 real watts/2 ohms from twin 600-watt FR Series High-Current power amps *Power amps switchable as stereo mains or main plus monitor *8 mic/line channels with master phantom power *Stereo line inputs on channels 7 and 8 *Inserts on channels 1-6 *Active 3-band EQ and stereo pan control on each channel *True stereo 9-band graphic EQ on mains and an impressive 9-band graphic EQ on monitor. All PPM Series Powered Mixers feature: Rugged injection-molded chassis resists impacts that would destroy a rat-fur-covered wood box powered mixer. Built-in handle can be used by folks who don't have the foggiest idea of what injection molding is. A real Mackie mic/line mixer section! Based on our world-famous MicroSeries 1202-VLZ and enhanced with new mic preamps and about a gazillion ingenious extra features. Rugged, sealed rotary controls resist dust, moisture and other contamination. Expensive, studio-grade, 9-band program equalizers for mains and monitor that utilize multiple summing amplifiers and precision infinite feedback band-pass filters, which yield superior linear-phase and combining properties. What this means is our graphic EQs are exceptionally low-noise, low-distortion, sound great, and don't suffer from any nasty phase-shift problems. Level-setting control & LED on every PPM mixer channel-makes setting input levels a snap. Mil-spec fiberglass circuit boards (instead of cheap phenolic) resist physical impact. Amp routing switch assigns power amps to mains or mains + monitors. Hefty 10,000µf storage capacitors for high peak power reserves. Massive toroid transformer for high current output. Mega-cool die-cast heat sink. 1-piece die-cast heat sink is custom-cast for maximum heat dissipation and minimum car upholstery destruction. Black coating improves efficiency by 15%. Running Man figure improves coolness-factor by 150%. This pa is amazing, Comes w/ power cable and manual. If your interested in a top of the line pa system without paying top price. Than this is the deal for you!
If interested please contact me by e-mail at cmanzo.1@netzero.com
or by phone at 1-386-801-2076
