The Poll Model won't fit: 5 Questions.
  • Thread starter Thread starter drstawl
drstawl
drstawl
Banned
OK- I'm asking you to name names.
What Amp do you use for your monitoring Circuit ?
Q1: Consumer/Professional Answer C or P
Q2: Output per channel: Answer- number reflecting the RMS watts per channel on a stereo amp or half that for a mono amp.
Q3: Noise Floor: When you have this bad boy plugged in and there is no signal applied to any input, and you have the volume cranked to 50% how bad is the hiss?
Answer:
A) What hiss?
B) Not bad.
C) I'm sorry but this Amp sucks.
Q4: Brand/Model Yes- Name Names!!!! Answer: ME: SONY DE-315
Q5: When did you buy it? Answer: a date.
My unorthodox choice:
1. Consumer
2. I'm not sure if this is what you're looking for, but from the spec sheet:
Minimum RMS Output Power per Channel: 8 ohms, 20Hz to 20kHz, 0.04% THD = 70W 6 ohms, 20Hz to 20kHz, 0.06% THD = 80W
Dynamic Power per Channel: (IHF) 8/6/4/2/ ohms = 100/120/145/170W
3. A. At full volume, I can hear a bit of hiss when I put my head next to the speaker. Too bad my sound card doesn't fare as well - when the receiver is set to monitor that channel, there's quite a bit of hiss at half volume.
4. Yamaha Natural Sound RX-495
5. December 1998.
One of my monitoring chains (the other is powered mons) uses:
Professional
150 watts RMS per side....
Q3: Noise Floor:
A) What hiss?
Hafler P3000
Late spring 2001.......
1. Consumer
2. 40W per side @4ohms
3. I guess there's some hiss, but I never really paid attention to it until you asked. Thanks a lot. Heh, no it's not really noticable.
4. NAD 3020
5. ~1980 :)
Slackmaster 2000
Professional
Monitoring? Ashley Power Amp with Quested Nearfeilds.
Output per channel: 250 rms
No Hiss
I've had the quested boxes for a year...the Ashley power amp is brand new seeing how my old Hafler finally kacked.
1 - Consumer
2 - 50wt per channel
3 - What hiss?
4 - Hafler TA1000
5 - August, 2001
1. C
2. 150 watt per channel
3. what hiss?
4. Technics
5. Circa 1996
q1: I would like to call it pro, since its not marketed to consumers but. P
q2. 75 watts/channel into 8 ohms
q3. at 50% power, the hiss is not there.
q4. Alesis RA-100
q5. Bought sometime in June 2001
this will blow your mind
P
700W
A) What hiss? very, very clean, at mark 2 on the power meter (all I need)
Mackie FR 1400i
Bought in January 1999
H2H
Q1: Consumer
Q2: 100W/ch
Q3: What hiss?
Q4: Modified NAD 2200 PE
(I designed a completely new balanced input section, Low ESR caps directly coupled to the output transistors, and bypassed the output relays)
Q5: Bought used in 1992
(only $80 thanks to the crackle from those notoriously unreliable output relays[I think it went for over $500 in the mid 80's] - plus I got two heavy duty computer cooling fans that the guy tried to 'fix' the problem with.:))
barefoot
High end Professoinal-Alan parsons used the same model for the Floyd LPs
400w per channel
Impecably Clean no hiss at 100%
Phase Linear Model 400 series two
Last july at a Garage sale for 20.00:cool:
