L
lunatic
Member
I'm finally to the point where I can plan out my space... Woo Hoo!
The Details:
The Details:
- The room is 23' 4" long by 11' 6" wide by 9' 9" tall.
- There is already electrical and the walls are insulated and covered with 1/2" drywall.
- There is one steel external door allowing access from the outside and a pair of double-doors inside the room that open into a garage.
- There are two 3' by 3' windows each 4' off of the ground.
- This space and the garage are in a single building that is detached from the house.
- Float floor. Run 3 dedicated audio circuits and audio wiring in floor.
- Install Pergo.
- Retexture walls (original texture job sucks).
- Paint, etc
- Install baseboard heat.
- Treat room acoustically[/list=1]
Initial Concers:- If I float the floor how do I accomodate the steel external door that swings inward? Do I build a ramp? Do I raise the door?
- Would a floating floor be even worth it without floating walls, etc?
- How the heck do I vent this space? Fresh air would be nice.[/list=1]
The goal is to be able to track and mix in this space. Most of the time the tracking would be just me but I have had interest from solo artists to record so, I would say, if I could track 3 people max at a time that would be great. 3 may be pushing it though. I'm guessing the space is too small to partition effectively. Maybe some gobos or something?
Another thought my wife and I had was to finish the garage in such a way that we could track in there. Only problem is, it has to be able to be used for cars as well. The idea being that when we need to track we simply remove the cars.
Hopefully some of you will have some thoughts and input. Any advice or direction is greatly appreciated.
Here is a link to a page with 2 versions of the room. One version is a bitmap (.bmp) and the other is a SmartDraw (.sdr):
Studio Dimensions
Peace,
Brad
