A
abbruzzese
Hi!
I'm thinking of buying this card, but I have few questions that I'd need help with.
1. How many tracks it is possible to record at a time, and I mean analog inputs? There is one analog input on the pci card itself and another on the front panel, right? but can I use phono input allso(I mean can I switch the riaa of)? So that would make 3 stereo inputs / 6 mono inputs + mic total ... Is this possible?
2. Does multitrack recording work with cooledit pro 2.0? Has anyone tried with this card?
3. Can mididata be recorded at the same time as audio?
(depends on the software, right?)
4. Can I use those rear/lfe/center outputs as normal stereo output?
Or should I consider some other card... I'd like to be able to record at least 2 stereotracks at the same time, and midi connectors should be also. And low latecy time, because I'm thinking of triggering drumsamples via midi using e-drumkit.
But it shouldn't cost more than 200-250$
..and sorry my bad english
