ido1957
9K Gold Member
Tell me about normalization - what is it and what does it do?
It was a semi-handy thing to have 15 years ago.
Eh, come to think of it, no it wasn't.
In concept, it "can" be used to level the sound of a CD so that everything will sound approximately the same volume. In my very limited experience, it just makes the CD sound like hell because it usually butchers the peaks and yields a bunch of square waves. Not a good tool for that use. In fact, I'm not sure what it is good for....
Haha.As it relates to 99% of music recordings, I agree with John here.
However, there are many instances where normalization of the audio file still applies. In voiceover work, nearly every client or post facility requires that a raw voice track is normalized to a "standard" volume level. A couple of years ago, that meant -3dB; nowadays it's often -1dB (which is ridiculous as it often degrades the quality of the audio). Personal feelings aside, most clients won't consider or accept anything that isn't normalized to at least -3dB. As NYM points out, I - and most others who do commercial VO - use a multi-pass normalizer that first scans the audio file to determine the loudest peaks, then actually processes the audio data on the second pass. The whole process takes less than 20 seconds or so for a standard 30-second radio read.
not at my studio (which is in your backyard)...I turn all "normalized" audio way down anyway. It's really pointless to send it normalized as I prefer to work with the raw recordings. I'm more interested in the RMS levels and how my levels will translate in the analog world (ie. when bumped to Beta SP)
They certainly seem to turn up the volume when broadcasting commercials. I wonder if they've done any studies on the success of TV commercials relating to loudness:I do notice that most tv commercials are "crystal clear" most of the time. Thus, I don't think my ears are losing my mind yet.
Any thoughts?
Green Hornet![]()
I have this kind of "related" question about normalizing.
WHY is the audio so BAD on television? Each time I hear a different channel, I get a different sound. Some loud. Some fine. Some too soft. Needless to say, some of the actors cannot articulate very well which is just garbled.
I wonder if the change to digital machinations will turn out "better?" The signals heard on a TV set will still be Analog sounds but better enhanced via digital signals?
Any thoughts?
Green Hornet![]()
BTW, where are you in KC? I'm at roughly 8th & Central...
