B
BaneInstitution
I am literally on my knees at this point because I've bought 2 of these things and they absolutely refuse to work properly.
Basically the main symptom I am experiencing with this thing now is that whenever I turn it on it works perfectly for about 20 seconds (sometimes less, sometimes more). The sound quality is clear and there is near-zero latency. However after these 20 seconds have elapsed the sound will rapidly degrade into a horrible, inaudible graininess that lasts for about 15 seconds, after which it clears and reverts to working fine again, except the latency will now be awful (literally a 1.5 second delay. Not just in my DAW- every sound that comes from my computer is delayed, rendering videos out of sync etc).
At this point it will be working perfectly and will be completely stable, except for this unacceptable and pathetic latency.
Here's a list of stuff I've tried and some other relevant information;
- It is plugged directly into the wall (not into a power strip).
- It is plugged into a USB 2 port using the supplied cable.
- I have tried other cables with the same (sometimes diminished) result.
- I have also tried a variety of USB ports with the same result.
- It is sat on top of my studio rack at the moment, on a flat wooden surface. I have also tried it on my desk with the same result.
- It is properly ventilated, both from the top and rear.
- The relevant 64bit drivers are installed correctly and up to date.
- I have 16gb of ram installed.
- It is properly set up in all of my DAWs.
- Presently (other than my keyboard and mouse) it is the only thing plugged into my PC via USB.
- It is plugged directly into a port on my computer, and is not going through a USB hub.
- It is not plugged into any other audio hardware save or my headphones and monitor speakers (both of which I know to be functioning and very reliable).
- Nothing else (microphones, etc.) is plugged into it.
- It is the default playback device in my control panel.
- No other audio drivers are installed.
- I have experimented with all the settings in the Tascam control panel. They either do the exact same thing or nothing at all.
- I am testing it with only one application open (Ableton or iTunes) and the result is the same.
- I have followed the instructions in the manual to the letter, from setting up to usage.
- I've tried it in my laptop whereby it works better, but the sound will occasionally drop out and start popping for a few seconds.
The irony is, I bought this to replace my cheap $12 behringer audio interface, but the TASCAM is being outperformed in nearly every category.
I am seriously at the end of my chain with this, I've invested huge amounts of time and money trying to get this stupid bloody thing to work but I have absolutely nothing to show for it.
I will honestly and sincerely give 50 quid to the paypal of the person who gives me the advice that gets this working.
