tascam m600 confusion
  • Thread starter Thread starter bbrown
B
bbrown
hello, i am new to this forum but i joined because ive read some pretty good advice here. my problem is with my m600 console. heres what i want to do but cannot figure out proper patch sequence. i want to use the send and returns for the 1-8 mixer channels to run through mic modeler and compressor but when i remove the jumper cables patching the two together so i can run seperate dsub cables to the patch bays i lose the ability to moniter the incoming signals through the control room. i am using the aux channels for seperate headphone sends and assigning mixer channels to the sub group outs to be fed to delta 1010 into computer running samplitude 7.22 and saw studio 3.0. the manuel has shed no light on how i can get my signal back again for monitering purposes. it has worked fine with my old setup of just recording from the direct outs and not using the send and return setup but what good are these outputs if you cannot hear the end result. ive tried the stereo outs, the studio outs the master stereo outs and so on could someone please give me some advice. also, i dont want to use the direct outs for feeding the recorder due to them being unbalanced,i want to send a balanced signal to delta 1010. thanks, bj brown
man....check your other post.
geez, stop the crossposting please?
Soooorrrryyyy...........for Not Knowing All Your Little Rules,i Said I Was New And I Was In A Hurry To Try To Get An Answer Maybe I Should Just Look Elsewhere C-ya
OK...I actually offered help and some great hints in the other thread.I even offerded to make some cables for ya but oh well.
