Ok...
- The DP-01/FX only has 2 basic, raw inputs, with no front-end mixing, whasoever.
- Choices of inputs are: 1-input to 1-track, 1-input bridged in mono to 2-tracks, 2-inputs to 2-tracks.
- There's no facility to mix 2-inputs down to 1-track.
- There's no input mixing whatsoever, just input-to-track architecture.
- It only records 2 tracks at a time, max.
- Small LCD screen, not backlit.
- A mainly menu-driven device, including menu-selected EQ frequencies.
- The "std" only has 2-1/4" inputs, and you must get the "upgraded" FX model to get just 2-XLR mic inputs.
- Despite Portastudio "looks", it's very unlike a traditional Portastudio, & is more like any other device in that class, such as the Fostex MR8 or VF80.
The lack of front-end mixer function, simple 2-input architecture & 2-track simul/max recording limit pretty much kills it for me.
The traditional Portastudio, such as the 424mkIII, has 6 full mixer strips for input and output mixing functions. There are 4-XLR inputs and another 4-1/4" inputs, totalling 8-inputs. The EQ is 3-band, w/mid-band sweepable, and EQ may be used on input and output mixing functions. You may mix 6 (or more) inputs to [1-4] tracks, inclusive. It has 2 EFFECT-Sends, w/one EFF-SND doubling as CUE monitor system. It has a highly visible, 2-color flouro-luminescent display. You may record up to 4-tracks simultaneously.
When you compare the DP-01/FX to the Tascam 388, the DP's inadequacies are more glaring, and there's simply no comparison. The 388 has a full functioned 8x8x2 mixer, 8-XLR inputs, 8-1/4" Line inputs, 8-dedicated ACCESS-SND-RCV jacks, 3-band sweepable EQ, 2-EFF-Sends, full monitor system & records 8-tracks simultaneously. It has 10 highly visible traditional lighted VU meters.
If you're geared toward the Fostex MR8-type of device, including the Tascam Pocketstudio-5, Boss BR-532, Pandora PXR4, or Fostex VF-08 or VF-80, then in comparison to those devices, the DP-01/FX looks like best in it's class.
As compared to the 424mkIII or, heaven forbid, the 388,... the DP-01/FX is a thoroughly inadequate high tech tinker toy. Even the 488mkII blows it away,... not to mention the 688.
This is where I say, "YMMV".
Thanx for asking.
