T
Travis Watson
Hi I've been recording through my DP-32sd for about a month now and have a few questions.
I'm asking about the DP-32 and 24 because I'm assuming they are the same.
How do you get reverb working?
I can not get reverb or any other effect to work or show up in the mix.
I have all the settings that the manual shows, I have everything turned on and hte send knobs turned up and am getting nothing.
How do I know if the compression is working?
I have all my compression settings set and it's turned on but I can't tell by listening and on the master meter it doesn't appear that it is working because the signal is still going into the red.
Is the only way to record to tracks 9-32, is to bounce them from 1-8?
Because you can't set imput H to record to track 9/10.
Thanks for any help,
Travis
Travis
