Tascam DP-02CF EQ
  • Thread starter Thread starter QuickJD
Q
QuickJD
OK, this is my first post here. I'm fairly new to home recording, and have a DP-02CF. I'm not sure just how the EQ settings work. I know you can adjust the high and low bands...but how much of the band are you affecting? Say you set the high band to 100 (it's default, I think), what range are you then working with? Does that make sense?
Thanks,
Jeff
Thanks,
Jeff
These are shelf type EQs, so for the low EQ all frequencies below your selected frequency are cut or boosted depending on which way you turn the knob, and for the high EQ all frequencies above your selected frequency are cut or boosted. The slope of the cut or boost is set by the designer.
If I remember correctly, you can also adjust what frequencies you are assigning to the high and low EQ through the menu. It's been a while since I've used mine, but I think I fiddled with that feature a little bit.
