Tascam DP-01 EQ question
  • Thread starter Thread starter Dad_of_four
D
Dad_of_four
I've posted to both the Tascam and the newbie forum, not sure if it belongs here, but wanted to give it a shot. Thanks for the patience.
My DP-01 has Semi-parametric EQ and each individual track can have the high and low set at different levels (i.e. Low can be set between 32Hz and 1.6kHz and High can be set between 1.7kHz and 18 kHz).
How does this work? If I lay down a bass track, and I want to mess with it, say I set the low at 60hz, and tweak my EQ low knob (I have a range that rolls from -5 through -1; center; and +1 through +5).
What am I affecting and how much am I affecting it?
If I set the EQ High for 400 Hz (same eq knob positions as above), again how much am I affecting and what am I affecting?
Also, what happens beyond those frequencies? Each - or + increment on the EQ High and EQ Low, what is that affecting and how much is that affecting it? :confused:
Thanks for taking the time.
Patrick
