Tascam 488 Manual or CD
  • Thread starter Thread starter robbycoe
R
robbycoe
Just purchased a used 488 PortaStudio, no manuals came with it...looking for manual or CD if one exists. Suggestions..Thanks.
I also have an older 07 Tascam...tried using the same casset tape to test 488 machine I just purchased on Ebay and when I hit the play button nothing happens..tape is TDK D90 IEC/TYPE1, perhaps there's some magical button I have to press to get the machine to work. It fast forwards and reverses but no play or record fucntions working Any tips...would appreciate any suggestions. Thanks
Hello.
There was a link to a DL of the 488 manual. I'll see if I can dig it up, later this morning.
When the Play/Rec forward tape motion does not work, but FF/RW works okay, it most often indicates the capstan drive belt has broken or slipped off the pulley/flywheel, and needs to be replaced. Such is the way of some Ebay deals. Shipping could have affected a loose belt to slip off, just by jostling it around. You get the picture.:eek:
/DA
Manual for 488 and play/rec. problem
Many thanks on the information. look forward to hearing on the manual.
You're quite right on Ebay deals, looks like a job for mechanical man.
Rob
Sorry, I was mistaken. I have no link to any online source for this manual.
I suggest ordering the manual from Tascam Parts, at (323) 727-8480. They'll sell it for a reasonable charge. No DL available, AFAIK. :eek:
Aaaagh!
I don't know why I always misquote Tascam's number, since I call it often enough!
Tascam Parts' CORRECT NUMBER is (323)727-4840.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :eek:
