Tascam 48 VU lamp replacement
  • Thread starter Thread starter affirmed
A
affirmed
Anybody here have experience with changing a VU lamp on a Tascam 48 reel to reel?
Any info would be helpful.
Thanks, Don
Yes.
Its a bit of a pain...you have to pull he meter panel off and whatever else is necessary to do so, and then IIRC the meters are individual but in order to get to the lamp you have to either remove ALL the meters or de-solder the one that is affected, and then the lamp is a soldered-in type. Totally doable, but not like replacing a light bulb in the ceiling of your chosen dwelling.
Thanks for the advice. I dug in & removed the meter panel cover. After removing the clear tape, the meter lid popped up & made it easy to access the lamp. I had some 7 volt lamps left over from a Teac 3440 I worked on & they worked like new. The whole job took less than 1/2 hour.
Now if I can get a copy of the users manual , I'll be set.
Thanks, Don
