Tascam 424 Newbie Question
  • Thread starter Thread starter BadFish
B
BadFish
I have an old TasCam 424 portastudio and i am recording some acoustic tracks, 1 track guitar other vocals. I am still getting use to setting the levels correctly. My question is this? Can i fix the levels during play back? When i listen to the playbackup of what i just recorded i cant change anything, anyone know how i can fix it?
Thanks
You should be able to raise the levels for playback BUT if you record with low levels you will also raise the level of tape hiss. Getting the levels right to begin with is the first and most important step in recording, especially with analog casette.
424 play back
im working with the exact same recorder you are, and i am assuming you want to ajust levels with the faders and not just the tape cue knobs. so here goes, and this is straight from the manual.
1.raise the master fader to the shaded area between 7 and 8
2. press the left and right monitor selector switches. the cue monitor must be UP.
3.set all input switches on the four input channels to thier center tape position.
4. press play, and while listening to the tape play, use the channel faders to set each tracks relative level for the desired balance. the channel 1 fader is being fed with track one, and so on for the four tracks.
5. from here you can adust each tracks left and right position with the pan controls, for the desired stero image. you can also e.q. eack track in this mode for desired tone.
this is in the mixdown section of the manual.
but heed texroadkill's advice, and get a good recording level to begin with or all this other stuff wont matter( im learning that the hard way)
hope this helps.
later.
oh yeah
MAKE SURE YOU ARE SETTING YOU TRIM CONTROLS WHEN YOU RECORD.
Thank you Both,
That was what i was looking for, i have the manuel but i didnt see that, i'll look it over again.
Thanks Guys,
BadFish
