The manual describes how to set it up to factory spec, including tape bias, levels, tension and such..... Have your tech follow the manual closely.
While some people use 1.5 mil tapes such as 456 (and God forbid 499
), it is not advisable according to TEAC. The tape is physically harder to pull and may put undue stress on the motors, not to mention wear the tape path faster and not conform to specs of the 388.
I don't recall what operating level the 388 was set at from the factory [check manual] but have your tech not stray from that number (and check / set it as per the manual).
When this is done and the 388 setup, as per the service manual, you can then take your pick of just about any 1mil tape such as Quantegy 407, 457, EMTEC / BASF / RMGI LPR35 and of course the Maxell UD series. All of these share nearly identical bias levels and can be interchanged.
Note that while the Maxell and 407 have a +3 op level, the 457 and LPR35 have +6. That should not matter at all, however, as you will stay well below saturation anyway.
