TASCAM 388 Problem
  • Thread starter Thread starter davin410
D
davin410
I recently found a Tascam 388 for really cheap. But the seller says that it sometimes doesn't record on tracks 1 and 8. He said that it can record on those tracks but you would have to turn the treble all the way up to hear them. I was wondering what this means, or what needs to be fixed and how much it might cost. Any help would be greatly appreciated. Thanks.
It could mean a few different things.
It might just be a build up of dirt on the heads and guides that the owner never cleaned off properly and let it get to a stage where Q-tips and alcohol won't be strong enough of a solvent to remove that grime. Stuff like Methanol or paint thinner might be needed to truly clean it up?!
It might also mean that the heads are worn out.
It might be a question of the owner using old worn out tape with edge track damage to the oxide layer of the tape.
It might mean that the transport, (heads and guides), needs to be demagnetized.
It might be a combination of all of these things or none of them too.
Your best bet is to get an estimate from a qualified service facility to really get to the heart of the problem.
Will the owner allow you to do get it checked out by your own mechanic, as they do in the car world?
How much is he offering the unit to you for?
Cheers! :)
He's offering it for $200, compared to the $600 bid I recently made, and lost!, on ebay. And it's local. So I guess I should just ask him if he'll let me have someone look at it. I just need to find someone to look at it. Do you have any suggestions for the Los Angeles area?
Yes, me. I could help you today!!
Pm me, I guess. I was heading down to LA today.
:eek:
