Thanks Beck! I can't find my camera but I'd say the tape is circa. 1980s. I sourced 1/4" Ampex 456 as, from some research, I'd read it was compatible. So, in your opinion, the problem's not a slack belt but the wrong tape right?
Yes that tape is absolutely 100% the problem if its pre-1995 456. There may be other problems, but you'll need to get new tape to properly run your 388 through its paces. Sticky-Shed Syndrome is one of the most important things you can get familiar with in the analog tape
world. Tape machine issues are very often tape issues, and many people spend big money before they figure it out. In fact many of the parts machines you see on eBay were perfectly good, but the owners were clueless about sticky-shed syndrome.
Also 456 is not recommend for the 388, but rather 457, which is the 1-mil (thinner version). In combination with sticky-shed the thicker 456 will make things worse. The 388 transport is not the most robust. Tascam officially recommends 1-mil tape for the 388, like 457, 407, BASF LPR-35, Scotch 207, etc. Tascam
original product literature for the 388 recommended Maxell 35-90.
Be careful with your research. Music recording forums on the web are rife with error and misconceptions. I rarely see anyone who fully understands the sticky-shed tape issue anywhere else but this forum. Well-respected members on gearslutz, Tapeheads, Tape-Op, etc are dead wrong about many things concerning different tapes and their properties. Even wikipedia is full of misinformation about sticky-shed.
Dump that old Ampex tape and get at least one unopened reel of known good tape to test your 388. It does not have to be brand new as long as its sealed. Any of the following will work:
Quantegy 457 or 407
3M/Scotch 207
Maxell UD 35-90 or XL 35-90B
Radio Shack "Supertape" 1800
BASF, EMTEC or RMGI LPR-35
When it comes to tape ask here first! And see my Sticky-Shed Tape Thread at the top of this forum.
Slow rewind/fast forward is the most common Sticky-shed tape symptom. Before you run new tape you'll want to thoroughly clean your tape path, heads, guides, rollers, etc. You'll need to get all the sticky-shed residue off before you continue.
