Tascam 388 Channel Access
  • Thread starter Thread starter satuyrn
satuyrn
Hi. I've searched and searched, but can't seem to find a thread that has anything on the subject I'm looking for.
I am using a Tascam 388 as an external mixer into a Tascam US-1640 (Digital USB 2.0 Interface) on an iMac. I have the channels routed from each "SEND" in the "ACCESS" section of the 388 to each 1/4" LINE IN on the 1640 w/ 1/4" cables. My question is this:
Is the "SEND" of each channel on the 388 pre or post EQ / Fader?
Here's my dilemma. I started taking levels and with the trim knobs barely turned up, I am clipping on the computer. However, the VU meters on the 388 are not clipping (they're peaking nicely between -3 & 0). I'm guessing that the "SEND" is happening BEFORE the signal gets to the EQ / Fader, and that's why I'm having trouble. I've read recommendations in other threads to use the PGM Buses as an access point on the 388, instead of each channel's "SEND".
I can easily start using the PGM Buss Outs... but they are RCA's... so I'd have to replace all my 1/4" cables and re-route them w/ RCA to 1/4" cables. I'm trying to avoid this, but it wouldn't be the end of the world if I had to. It would be nice to know the info on each channels ACCESS section, though, in the event that I want to use them in another way, some other time.
Thanks, in advance, for your help. If you need other info to help answer my question, please let me know.
Greetings, Satuyrn...
The SEND jacks on the 388 are post eq, pre fader.
The meters monitor the PGM busses, not the pre-fade level on the input strip so its not worth referencing them unless you run a known level test tone into the strip, check the level at the SEND jack and then adjust the level at the corresponding BUSS OUT jack to zero the meters to the input TRIM pot (and then you leave the channel faders and BUSS L & R faders alone).
This is all way too kludgey for me.
Either figure you ignore the meters and adjust the output sensitivity of the 388 at the SEND jack with the TRIM knobs and the input sensitivity of the 1640 with the input trims, or you use the BUSS OUT jacks (which is more ideal to how you are using the mixer IMHO) and just get 1/4" TS --> RCA adapters. Pretty cheap and that way you can still use your 1/4" to 1/4" TS cables.
By using the BUSS OUT jacks you:
  • Have the advantage of being able to use the meters to monitor the output of the 388 mixer
  • Can use the 388 input TRIM as it should be used (to maximize the input signal strength to the strip to keep the signal as far above the noise floor as possible rather than being tied to using the TRIM as a send level knob)
  • Don't have to pull your hair out trying to get adequate gain on the rest of the busses (i.e. EFF and AUX busses and main buss for monitoring) since it sounds like your input TRIMs would have to be set low which would force you to over-boost the rest of the gain stages and you'd be boosting a lot of noise from the input TRIMs since those would be lower to the noise floor.
My 2p.
