Everton 246 problem 2
You were correct, when I went back in and looked at the tires they were discussing. totally melted. What a mess. I since (as of yesterday) have replaced the two tires and cleaned up the reels and the spindle. The machine now will play, rew. and ff. Thank you.
However, I have now encountered a second problem. When I put a pre-recordered tape in the machine and pushed the play button everything looked normal. The meter bridge was working as were the pgm out meters.
I noticed that the DBX light was blinking so I turned off the switch in the rear and it dutifully went out. I then turned it back on. making a decision I wanted to listen to a tape I hooked the left/right Monitor outputs to my RX.
Turned the tape machine on and pushed PLAY the tape plays but I have nothing on the meter bridge and no sound output ANYWHERE. I checked the meter bridge with a microphone and a record player and the bridge is working, but I still have no sound from the cassette. The output amp is working because I can listen to a record from my turntable.
This seems to be a coincidental action with my turning ON and OFF the DBX switch....or the playback head. (that's odd because it did play when I first inserted a cassette.) Any ideas???
