B
brettf
Whats the most you would pay for a good condition 244, recently serviced?
$100 to $125 for a minty one.
Many of them sell for $50 or less when they need a belt and cam drive change.
Cheers!![]()
I have one (along with original instruction manual) that needs work to be functional, that I'd love to sell, but it would probably cost more to ship than it's worth. Can't bear to just throw it out, though.
What to do?
Anyone in the LA area looking for a fixer-upper?![]()
I have one of those. I spent $50 for a beat up one. I put $100 or so into it and it worked like new for a few days. Then the NR started getting wonky and $150 later I'm back to square one.
dbx type II behaves quite a bit differently then type I does so you really have to be careful of your recording levels and watch out of percussive low end content as it can create the false triggering artifacts in the bottom end where the dbx stops processing below 100 HZ and you end up with the breathing/pumping distortions. If you try to keep the average VU meter readings between -7 and -3 VU, when recording, you'll reduce those issues by a good degree. A proper calibration wouldn't hurt either as almost no one ever does that as an end user. If calibrated back to factory spec for levels and bias, you'd also find that the dbx become far less of a problem.
Cheers!![]()
Just in case anybody's wondering, I'm a HUGE fan of the word "wonky".
Um, That's a Macsat 414...
Cheers!![]()
Ghost -
Thanks for the help, it seems to be working. Perhaps it could use to be calibrated. When I back off below 0 a few db it sounds great. I guess I don't have to be afraid of that with the DBX. I'm used to trying to maximize the levels with my open reel decks (with no NR).
I doubt I'll use the 244 now that I have the Nagra, so I'll use it a bit to make sure it works then probably sell it. I just wanted to have a portable tape machine.
