Tascam 244 and condencer mics
  • Thread starter Thread starter Illsidgus
OK - Condenser mics need "phantom power" to make them work.
In most professional mics, this is provided by the mixing desk/interface/preamp as phantom power (48 Volts).
SOME condenser mics will work with an internal battery (need to make sure the battery isn't flat, and that the mic is switched on [I KNOW this sounds basic, but surprising how many times people miss this]).
If using phantom power from a preamp (such as your Behringer preamp) you again need to ensure Phantom Power is switched ON at the preamp, and the mic is "ON".
Phantom-powered condenser mics (i.e. those without batteries) will not work directly with a 244; the 244 does not provide phantom poewer.
In this case, you need a separate phantom power box between the mic and the 244.
There's a company called ART who make a great range of phantom power boxes, also DI boxes and a host of other really useful stage and studio problem solvers at reasonable prices. Check out artproaudio
No reason why you shouldnt. On some of these machines the line input doesn't go through a pre-amp so you need a separate one.
Replies
22
Views
14K
bouldersoundguy
bouldersoundguy
