E
easyeric
just picked up my first tape deck, a little Tascam 22-2! I gotta first say thanks for all the great information posted on this board over the yrs about tape decks...I've been living in the archives...
anyways, I hope my question isn't redundant, but I thought it'd be easier to fully explain my situation and what I've have/haven't done so far.
First, the problem: on playback of a recording I made (a test tone), the Left Channel is not coming through properly. The sound continually fluctuates, and has a very muddy quality to it overall (In both the headphone jack and Line-Out). The Left VU on PBack visually comfirms that fluctuating sound. The Right Channel is perfectly fine, and the Right VU maintains a solid level at 0.
What I've done so far: my first dumb guess was maybe there was a bad connection going into the 22-2 from my Tascam M-312. I switched around cables and tried different outputs. But, when you monitor the 22-2's source sound from the mixer, it comes through perfectly in both channels, and the VU meters confirm that.
I cleaned the heads throughly with Head Cleaning solution, they were actually a bit dirty, and the PB & REC heads don't seem to have too much wear from what I understand about head wear (uh, not much)...
I tried recording on 2 different brand-new tapes (Quantegy 480), both had the same output.
I'm not sure where the problem lies, maybe the heads are in worse shape than I think?!
Hopefully, someone can lead me in the right direction. Thanks fellas!
