famous beagle
Ok, so, this is from my Fostex R8 Owner's Manual:
"The R8 is designed for exclusive use with 7 inch or 5 inch reels. Since a 7 inch reel of 1 mil (35um) tape is 550 meters (about 1800 feet), the maximum recording/playback time is approximately 22 minutes.
The bias and equalization of the R8 have been factory aligned for use with Ampex 457 or equivalent high-quality tapes (such as Scotch 227).
So I thought, "Ok, I need 1 mil tape, equivalent to Ampex 457." But then, after having an issue with playback speed (as described in my thread "Fostex R8 issue... please help"), I downloaded the R8 Service Manual. And it says this:
Tape:
1/4 inch (6.35 mm) tape width, 1.5 mil (35um) base
AMPEX 457 or equivalent
First of all, why does this say 1.5 mil when the owner's manual says 1 mil? And also, why are two different abbreviations used for millimeter (mil and mm)?
And to make things more confusing, this is from RMGI's site:
SM911 Tape
This is the excellent RMGI SM911 from Holland. The choice of archives worldwide (along with ATR Master Tape), this precision slit and coated tape is similar to 456 in operating level (+6) ... Each tape is 1200' in length of 1/4" 1.5 mil back coated tape on a standard RMGI 7" plastic reel. ... Bias Compatible with 456/457
and then, LPR35 Tape
This is the 1 mil RMGI LPR35 and is similar to AMPEX 456 and SM911 in operating level (+6). Each tape is 1800' in length of 1/4" 1 mil back coated tape on a standard RMGI 7" plastic reel. ... Bias Compatible with 456/457
So ..... my question (aside from the few above) is this:
Can the R8 accept either 1.5 or 1 mil thickness? And is the 1.5 mil thickness only available in 1200 feet rolls (on 7" that is)?
Thanks
Tape:
SM911 Tape
Thanks
